is there a setting to select which corner we want the corner probe to work with instead of the default bottom left corner? i want to run this from the bottom right and it probes the x and y sides just fine. it then slides to the back and right to start its top probe which is off the material.
my work around is to slightly slide the probe base over to match where the tool is coming down so it catches the top level correctly… but this is not ideal…
Sorry You just have Bitzero V1 and V2, and it is fixed operation. Of all the things CM does well, flexibility for other methods or other probes is not an option in CM. CM uses a keep you out of trouble workflow that they and us can give tech support on. There are other G-code senders for more advanced usage.
If not probing the lower-left corner for XYZ, the expectation is that at other corners, 3 probing operations will be made, and the unit re-positioned for the Z-axis probe.
