Just got my Shapeoko 5 Pro and apart from a few broken bits, all looks great.
I’ve also bought a bit zero and I was just doing some test cuts with it today to see how it works.
I noticed that when it moves around the inner circle, it nudges the bitzero down the y axis a tiny bit as it knocks it - talking max 1mm.
Just wondering if this is expected behaviour or whether this would reduce accuracy and should be worked around? (Eg I could hold the bitzero when probing to make sure it doesn’t move!)
I use the tooling pin and have the spindle disabled when I use the BitZero. But I physically hold it in place by hand since it’s movements are intentionally slow and predictable.
