-I just install the CM buid618 for Windows,
-when I start the probing routine it ask me to select the probe version V1 or V2, so I select V1,
-I select Z probing
- and before going any further I check if the LED go red if I manually touch the probe to the bit (the alligator clip is on the the bit) and the led turn red.
- So when i place the bit on top of the probe and start the process, the Z axis go down and then the bit touch the probe the led go red,
-but the Z do not stop going down , I have to hit the emergency because the Z axis is forcing is way down.
I know with the previous CM version the Zero probing was working.
What can i do for troubleshooting my problem. Is there some code in the GRBL config that need to be set?
