Hi all,
I have seen the old topic with the different connectors.
Quick question…for those who own both machines: How do you handle this?
Will @carbide Is there going to be an adaptor to use them on both machines?
If not, can you specify the connectors, so I could sort out a solution myself?
I can’t really get myself into buying to of them if the connector is the only difference.
As usual, any help / hint appreciated.
Thanks
Daniel
WillAdams
(William Adams (Carbide 3D))
2
The connector for the BitSetter on a Nomad 3 is different from that on a Shapeoko — you can see this difference in the documentation.
Not sure what the specific connector is for the Nomad 3 — for the Shapeoko it’s Molex KK, which I believe is called out at:
or see:
Hi Will, thanks for your quick reply.
I have a feeling the best is to go with a separate Bitzero for each machine then…
Daniel
system
(system)
Closed
4
