I’ve seen many people and I myself trying to find the correct connectors for the Shapeoko 3.
So I’ve compiled a list to have them all in one place. If you find any errors let me know. Also any connectors I may have missed.
Please note that there are many part numbers for crimp terminals.
Whether Tin or gold, Reel or bag and maybe more.
If you can’t find the one listed where you buy your parts, find the crimp terminal series and look for others.
On the Molex website a bit under the part number they will have: Series: 6838 with the number as a link.
Stepper Motor Connector
Manufacturer: Molex
Part Number: 09508043
Description: KK 3.96mm Crimp Terminal Housing, Friction Ramp, 4 Circuits, Natural
Series: 41695
https://www.molex.com/molex/products/part-detail/crimp_housings/0009508041
Manufacturer: Molex
Part Number: 08520113
Description: KK Trifurcon Crimp Terminal 6838, 18-20 AWG, Bag, Phosphor Bronze Tin (Sn)
Series: 6838
https://www.molex.com/molex/products/part-detail/crimp_terminals/0008520113
Stepper Motor Extension Cable Connectors
Manufacturer: Molex
Series: 41695
Manufacturer: Molex
Series: 6838
Manufacturer: Molex
Part Number: 26604040
Description: KK 396 Header, Vertical, Friction Lock, 4 Circuits, Tin (Sn) Plating
Series: 41791
https://www.molex.com/molex/products/part-detail/pcb_headers/0026604040
BitRunner V1 Cable - Controller Side
Manufacturer: Molex
Part Number: 430200601
Description: Micro-Fit 3.0 Plug Housing, Dual Row, 6 Circuits, UL 94V-0, Low-Halogen, Black
Series: 43020
https://www.molex.com/molex/products/part-detail/crimp_housings/0430200601
Manufacturer: Molex
Part Number: 430310007
Description: Micro-Fit 3.0 Crimp Terminal, Male, with Tin (Sn) Plated Phosphor Bronze Contact, 20-24 AWG, Bag
Series: 43031
https://www.molex.com/molex/products/part-detail/crimp_terminals/0430310007
OR
Part Number: 430310008
Description: Micro-Fit 3.0 Crimp Terminal, Male, with 0.38µm Select Gold (Au) Plated Phosphor Bronze Contact, 20-24 AWG, Bag
Series: 43031
https://www.molex.com/molex/products/part-detail/crimp_terminals/0430310008
BitRunner Cable - BitRunner V1 Side
Manufacturer: Molex
Part Number: 430250600
Description: Micro-Fit 3.0 Receptacle Housing, Dual Row, 6 Circuits, UL 94V-0, Low-Halogen, Black
Series: 43025
https://www.molex.com/molex/products/part-detail/crimp_housings/0430250600
Manufacturer: Molex
Part Number: 430300007
Description: Micro-Fit 3.0 Crimp Terminal, Female, with Tin (Sn) Plated Phosphor Bronze Contact, 20-24 AWG, Bag
Series: 43030
https://www.molex.com/molex/products/part-detail/crimp_terminals/0430300007
OR
Part Number: 430300008
Description: Micro-Fit 3.0 Crimp Terminal, Female, with Select Gold (Au) Plated Phosphor Bronze Contact, 20-24 AWG, Bag
Series: 43030
https://www.molex.com/molex/products/part-detail/crimp_terminals/0430300008
Controller PCB connector for BitRunner V1
Manufacturer: Molex
Part Number: 447640601
Description: Micro-Fit BMI Receptacle Header, Dual Row, Right-Angle, with Press-fit Plastic Pegs, 2.54µm Tin (Sn), 6 Circuits
Series: 44764
https://www.molex.com/molex/products/part-detail/pcb_receptacles/0447640601
OR
Manufacturer: Molex
Part Number: 447640603
Description: Micro-Fit BMI Receptacle Header, Dual Row, Right-Angle, with Press-fit Plastic Pegs, 0.80µm Gold (Au) Selective, 6 Circuits
Series: 44764
https://www.molex.com/molex/products/part-detail/pcb_receptacles/0447640603
Proximity Switch (Inductive), BitSetter (Shapeoko 3) and Original BitZero (Discontinued) to plug into Controller, 3pin
Manufacturer: Molex
Part Number: 22013037
Description: KK 254 Crimp Housing, Friction Ramp with Polarizing Ribs, 3 Circuits, Natural
Series: 2695
https://www.molex.com/molex/products/part-detail/crimp_housings/0022013037
Manufacturer: Molex
Part Number: 08500113
Description: KK 254 Crimp Terminal, 22-30 AWG, Hot Tin (Sn) Dip Plating
Series: 2759
https://www.molex.com/molex/products/part-detail/crimp_terminals/0008500113
OR
Part Number: 08500114 Planned for Obsolescence but Mouser had a ton of them
Description: KK 254 Crimp Terminal, 22-30 AWG, Bag, Hot Tin (Sn) Dip Plating
Series: 2759
https://www.molex.com/molex/products/part-detail/crimp_terminals/0008500114
Please let me know if there are any errors, I tried my best to make it correct.
Thanks,
Jeffery
