I have a Shapeoko 3 XXL, a few years old (S/N 2248, if that helps). I was installing the pwncnc dust boot and I ran into an issue with the bolts that attach it to the z-axis, at the top. The longer bolts provided with the dust boot are M5x0.5, but they don’t fit. So, I set about figuring out what the existing bolt is. Weirdly enough, it’s not metric at all. None of the metric thread checkers matched at all. But, SAE 24 tpi did fit:
Early machines had #10-24 threaded spacers and bolts for the stops — contact us at support@carbide3d.com and we’ll work out how to get you the correct metric part, or you could order them yourself from www.aluminumspacers.com
