This is a user forum, not a support mechanism… just so you know.
Edit: I think I posted this to the wrong thread, sorry.
I used 2.5 inch Peachtree Woodworking. This hose is very flexible. I am not in an enclosure but you need enough length your z can move to the 4 corners and not strain your z movement.
Hi Gerry
I am quite aware it is a user forum. David and even Will were trying to help. As a new user (I only finished setting my machine up yesterday) I thought I was doing something simple wrong. It turned out that was not the case. Will then sent some arbitrary message about making money from the machine and I should therefore download the pro version. I have actually downloaded the pro trial now but will not extend the free license, I will instead buy Vcarve (Nice Job Will). I have 5 years cnc laser experience so hope I can have valuable input into this community.
Carbide Create runs in 3 different modes:
- Free — this is the default and lacks 3D modeling but can generate G-Code http://carbide3d.com/blog/2017/big-carbide-create-update-its-now-free/
- Trial — this is enabled by Help | Enable Pro Trial and can be disabled by Help | Disable Pro Trial
- Pro — this requires a license from launch.carbide3d.com (note that this uses a different account than other Carbide 3D sites) but see: Carbide Create Pro - Free For a Year — you can paste in the license via Help | Register
https://launch.carbide3d.com — creating an account will allow a free trial. “This trial is fully functional … so you can generate G-Code and try a full project.”
That is where I downloaded yesterday, the version that simply did not work and gave me the problems above.
There’s only that one version, and it works for most folks, and runs in the three different modes as noted.
If you’ll let us know the specifics of your computer setup at support@carbide3d.com we’ll do our best to look into it.
