Has anyone noticed that if you set the Job type of Bottom Side Only, the entire design gets shifted to the right by a significant amount?
I don’t see that.
How are you generating your Gerber files?
Can you share your files?
P.S. I see you’re now using the un-beta beta version…did that solve the issue from your other thread?
I think this was a result of the dimensions of my gerber files not matching the material dimensions I put into Carbide Copper. I don’t see the issue now that I’ve made sure the dimensions match.
And yes, using the “save as separate g-code files” feature of v1.03 resolved my issue.
