I looked up feeds and speeds for the bowl and tray bit so this must be the issue.
5x8 tray .5" deep on 1.07 walnut 6" wide. (6ft)
CC says the bowl and tray bit will take 63 minutes!!
I fiddled with the stepover to do a rough pass first, then a finish pass but the preview was either completely smooth , not showing the ridges, or there was a big chunk not cut.
But 46 minutes with the 1/4" endmill that ships w/ your shapeoko so something off.
The “big chunk not cut” happens usually when the stepover is exactly half of the diameter. Try dropping the stepover to 0.370, Or bump it up a little & see what works.
18000 seems fast to me for a 3/4". But if it’s cutting well, go with it. If it starts to burn turn the RPM down.
You may be able to bump the feedrate up as well. Just watch & listen while it cuts & see what you can get away with.
For the RPMS I would not exceed 18,000 using wood.
I start out conservatively with the feed rate and depth per pass.
The feed rate can be manually adjusted with the program running in carbide motion.
Unfortunately it’s not plug and play, as it takes time and extra material to develop a complete program.
I’ve found it hard to give exact numbers because of the different variables involved with each project.
