so I know bowl bits are not official supported as real bits in CC. so I followed some suggestions about setting it up as an End Mill.
However I’d like to create a thin walled slopped valet tray.
I started with an 8" wide shape
Added a 0.1" inside offset and set up a double sided machining operation.
Now I think my interior slot discrepancy is coming from the lack of corners on my “end mill”
I guess for my next steps is I make the inner detail 0.2125" x 2 larger (which would be outside the outside) oi
WillAdams
(William Adams (Carbide 3D))
December 3, 2021, 11:37am
2
Why not just finish w/ a smaller ball-nosed endmill?
If you add a bit of geometry which matches where the flat are should be it would be omitted from a finishing pass, and you should avoid scallops — or flip things: use the smaller ball-nosed endmill first, then switch to the bowl bit after and use it only for the flat-bottomed area.
Terry
(Terry Box)
December 26, 2021, 2:01am
3
Did you get this worked out?
I want to try the same thing and am setting up a 1"D x 1/2"H x 1/2" Shank Dish Carving bit from Rockler.
For this first attempt, I’d be happy with vertical side walls. I just can’t find appropriate feeds and speeds online for this bit.
I created a tool using your numbers above and will give it a go.
Thanks,
Terry
system
(system)
Closed
January 2, 2022, 4:42am
4
