Draw a horizontal line.
Scale it to change the length to a specific value. OK
The line disappears. And you can’t select anything else.
I can confirm this behavior (757). It does not happen if you resize with the handles…only when specifying the width directly in edit box (it does not happen if you change the height of a vertical line). It also seems to only happen on lines. It also does not happen unless the line is horizontal.
Note: If you then try to create a new object, the Width and Height fields are set to not a number (nan) and cannot be changed…
if you try to create a circle, the radius is set to "-nan"
- Gary
Yes, we are aware of this and it has been filed as a bug since v738 or so.
