Bug: Fusion 360 DXF Flat Pattern Import Error
I generated a sheet metal part in Fusion 360, and exported the flat pattern as a DXF. When importing it into Carbide Create, it seems to be offsetting setting resulting in a bad import:
The same file opens correctly in Inkscape and Solidworks.
UJ Bracket - feb 17.dxf (4.5 KB)
Please try the new beta:
Works in it:
Ah, perfect! Thank you!
