So when doing boolean joins, sometimes if i select multiple parts, some of them won’t join. but then if i go select them individually, they do join. and eventually i can get them all to join. i’m sure they’re aligned, and the fact they’ll join individually but not when part of a group would confirm that. anyway, they say a pic is worth a 1000 words, well, a video is worth 10,000, so look at what i’m talking about below.
i’ve tried the current stable version as well as beta versions, same experience. any chance we can get a fix :)?
Please post the file and we will look into this with you.
Note that Boolean operations need to actually overlap — they don’t work reliably for merely adjacent since whether or no it works will depend on rounding of position coordinates.
i appreciate the response, but as a software developer myself, this seems like something that should be fixed on your end . if it was consistently not joining, and worked the same regardless of which nodes i selected, that would be different. but since just selecting different groups of nodes before the join causes different results, can you at least look into making it consistent?
I suspect that making it consistent would require a major re-working of the architecture and/or have significant performance impacts, and/or result in complex code which would be more difficult/involved to maintain/update.
Perhaps it can be done in a future update — we’ll have to see.
