Anyway to delete all these Carbide 3D tool libraries? Very annoying as I do not want or need them.
I think they are built in now so feeds and speeds can be selected by material and endmill. That way you won’t run your wood settings in aluminum or vise versa.
You can filter to only the one you want using the Material drop-down at the top of the window.
Note that with a slight spelling change (aluminium vice aluminum) this would hide the Carbide 3D libraries.
