MrGNY
(Michael Greco)
November 29, 2020, 11:25pm
1
Went to use my XXL and saw that there were updates for CC and CM. I did both updates and created my project in CC. Saved file and exported the G-Code. CM is not recognizing the file. The file is greyed out. Post processors selected is Shapeoko with homing switches.
Mac OS 10.15.7
iMac
Thanks in advance.
MrGNY
(Michael Greco)
November 29, 2020, 11:28pm
2
I clicked on file and did get info and added the .nc to the end and it loaded. Going to run and see if it works. Will post if the file runs OK.
bpedit
(Byrne Pedit)
November 29, 2020, 11:34pm
3
This seems to be a sometimes issue on my Mac, not just restricted to the Carbide apps, where the file type needs to be stated, not inferred.
MrGNY
(Michael Greco)
November 29, 2020, 11:50pm
4
Thanks for the feedback. I have never had this happen before in all my yrs using Mac except for maybe once or twice.
At least I figured out what was happening.
Goose72
(William McGraw (Butch))
November 30, 2020, 3:36am
5
I to have had this problem today after I updated CC thanks for the info I went back and added the .nc when I saved the gcode we will see if it works .I didn’t have this problem until the update on my Mac
WillAdams
(William Adams (Carbide 3D))
December 4, 2020, 6:03pm
7
You need to actually edit the filename, not the metadata.
WillAdams
December 4, 2020, 6:43pm
9
Your mention of the “Get Info trick”.
I don’t see how a filename with .nc couldn’t be seen by Carbide Motion.
Please post the file.
Do you have any other apps associated w/ .nc files?
Hopefully @robgrz can speak to file associations and extensions and how they interact with Carbide Motion and its File | Load dialog.
MrGNY
(Michael Greco)
December 4, 2020, 7:44pm
11
Cutting Board Test.zip (881 Bytes)
When the file is generated the .nc is not added at the end. Right click on the file to get the GetInfo window and in name add .nc.
bpedit
(Byrne Pedit)
December 4, 2020, 8:35pm
12
@MrGNY Why use the GetInfo dialog? Just add it directly to the file name in the desktop, saves clicks and mouse moving.
MrGNY
(Michael Greco)
December 4, 2020, 8:46pm
13
No reason other than was seeing if it saw the file as something else. Seeing if permissions may have been changed. Troubleshooting 101.
system
(system)
Closed
December 29, 2020, 11:39pm
14
