Having a little fun while work slows down and building a raspberry picade that will set on a coffee table and connect to a tv via HDMI. It has joysticks, bluetooth support, and USB for wired controllers. All that I have left to do is wire the power switch and setup the software.
Thought I would share! Designed 100% by me and cut in Poplar. I’ll probably make a few tweaks to the design and build another one, then stain and finish the wood.
