Does anyone have a C2D file of a butterfly image that I can carve with CM with some lines carved through the board thickness of a cutting board The through lines would provide drainage of the cutting board over the sink.
What size will you cutting board be. Height, width, and thickness. Where do you want the drainage holes and what size.
Just did this example for you, you can change as needed.
Butterfly Cutting Board.c2d (264 KB)
Loren … Just what I was looking for. Many thanks. I will be running the G-code template tomorrow.
I know I am late to the party on this topic but i just posted a youtube vide on how to draw your own butter fly.
Part 2 on cutting it in CCP 3D soon.
Have fun making saw dust!
