Since Carbide Create is closed source and those of us with programming chops can’t contribute I was thinking there might be a way we could indirectly add functionality by producing tools the interact with CC by programmatically mutating c2d files. I could see additions like:
generating geometry and toolpaths definitions (not g-code) that
1- effectively create a ramp for entries in contour cuts
2- effectively create helical entries for pockets
3- split up pockets into chunks such that something resembling adaptive clearing could be created (a bunch of circular pockets)
4- produce roughing and finish cuts
The file looks to be a pretty typical json format with a small binary blob at the end. So getting started with this task would be a matter of understanding the structure and schema of the document. Is there any official docs on the file format or has anyone put in effort to reverse engineeer?
