I think I’m right that the C3D Probe height is hard coded in CM.
I have DIY’d a probe and milled it’s height to 25mm ± 0.2.
I was wondering after you clear all offsets and with the C3D probe placed on the waste board what is the Z position on the “Set Current Position” screen in CM?
@kdan, wouldn’t that measurement depend on how people have setup their machine, for example whether the router sits high or low in its mount and which endmill they are using ?
(I would have done this for you, but I don’t have a C3D probe)
Or maybe explain what you are trying to conclude/achieve ?
@Julien, I might be going about this all wrong. After milling my DIY probe I just wanted to make sure CM would set Z height as though you were using a C3D probe.
But after you mention it, it would have factors that would not be the same from machine to machine. I was thinking that CM had the C3D probe height as a constant and I was trying to duplicate that.
As long as your DIY probe dimensions are identical to C3D’s, it will be allright. And even if they aren’t, you could then consider another G-code sender that lets you customize the probe dimensions (hint: CNCjs with @neilferreri’s wonderful probing macros)
