I am having a hard time getting the lines cleared up in this image. I used a polyline to redo the I and the two F’s but i don’t know what to do to straighten up the rest of the writing in the image.
Firefighter Maltese Cross.c2d (300.9 KB)
If you can find a better image:
which you can convert into a .png:
It imports pretty well:
and a bit of adjustment of the Threshold:
results in an image which is about ready to go:
Easiest thing rather than re-drawing the text is to re-set it:
And at need, import the pixel image as a background for reference:
and use node editing to tidy things up:
Thank you. I know there is an easier way but I don’t know how to put text into curves and things like that. I am pretty limited on what I know how to do with designing. I’ll definitely check out the file you sent. Thank you.
