Can I use carbide create with a openbuilds lead 1010 cnc
Hi All,
I’ve recently purchased a openbuilds lead 1010, I don’t have any internet where I live so I’m dependent on using a software the is not cloud based. Ive downloaded carbide create but when I try to select my machine I don’t get the option for openbuilds. Are these not compatible? Is there another programme I need to bridge the gap ?
Thanks
The machine type selection is an artifact from when Carbide Create limited stock size and calculated chip loads based on machine type — it no longer does these things.
You will need to select a suitable post-processor under Edit | Select Post-processor — this should be Grbl or Basic G-code.
