So if I buy Pro, can I use it on my desktop and laptop? I have my $4000 gaming PC that I use to design and set up everything because the screen is bigger, then send it to my laptop and cut it. Can I do that if I buy Pro?
You just install your license file on I think up to 3 computers. However I dont think C3D has any mechanism to limit how many you install on.
You can verify that by contacting sales at C3D.
You don’t need carbide create to cut, you just need carbide motion. It makes it easier when you have it on oth so you can edit on the fly though.
I have a similar workflow… design on a gaming PC and save to a network drive then access it on the PC in the garage that’s tethered to the Shapeoko. Having CC Pro on both is convenient so I don’t have to go back and forth from the basement and garage for small tweaks.
You can have an issue using multiple computers to design projects that is the fonts. Not every PC has the same fonts installed. So make sure if you install a font on one computer you install it on your other PC’s. Even the default fonts installed with the OS varies with different releases and updates. So make sure the same font you are using is installed on all your design computers.
