Trying to add Neil’s Post Processor to Aspire but keep getting errors.
After adding the file to “C:\ProgramData\Vectric\Aspire\V10.5\My_PostP” I restart Aspire and open it again. This is the first pop-up window that I get:
I copied the text from github, pasted into Notepad++ and saved it as a.pp file. Now it seems to work as intended.
One more question, as there are multiple files at Neils github, which should I use? What is the difference between “Grbl_mm_TC.pp” and “Shapeoko_mm_TC.pp”? Do I need both?
I’d recommend grbl_mm_TC.pp
The differences between the Shapeoko and Grbl have narrowed as they’ve improved.
I always recommend metric as it limits issues with arc precision (though those shouldn’t be an issue)
