I use a bowl bit quite regularly, it works great!
Three caveats
- Turn down the RPM on the router… like all the way down. They aren’t supposed to spin too fast
- They plunge pretty poorly, so set your plunge speed quite low (say 5 ipm)
- They are large and not super great for removing a lot of material at the same time, so keep F&S reasonable, something like 0.04" DOC with a 25-35ipm feedrate or so.
(if you feel the F&S are low… well, look at a high speed 1/4" endmill shape, with angled flutes aimed for quickly cutting and evacuating things… and then a bowl bit, which is just looking like a razor spinning around, no fancy advanced geometry etc)
