Can you use a bowl bit on the Shapeoko?
I know you would not use the bearing on it. I am looking to make juice grooves on some cutting boards and read some horror stories.
Yes, router bits w/o bearings which can plunge can be used with suitable feeds and speeds. Router bits w/o bearings which can’t plunge can be used w/ suitable feeds, speeds, and toolpaths.
I use a bowl bit quite regularly, it works great!
Three caveats
(if you feel the F&S are low… well, look at a high speed 1/4" endmill shape, with angled flutes aimed for quickly cutting and evacuating things… and then a bowl bit, which is just looking like a razor spinning around, no fancy advanced geometry etc)
I’ve got this core box bit set from Milescraft. I use the largest bit to cut the marble holders for Chinese checkers boards and it’s worked great for that. It’s a peck drilling operation so it’s not cutting grooves at that point. I’ve used the other bits for smaller projects where I need grooves as well, following the @fenrus advice. https://www.menards.com/main/tools/power-tool-accessories/router-bits-accessories/milescraft-reg-3-piece-core-box-long-reach-router-bit-set/22100700/p-1444440249651-c-10080.htm?tid=7768802776637002456&ipos=1
fwiw I have the whiteside bowl bit ( https://smile.amazon.com/gp/product/B000K2ADLY ) and it seems very well made…
but I suspect they basically are all similar in behavior
I love my whiteside bits, and I guarantee that’s a better bit than what I have. I think I got that set while in a rush and it’s worked great for a cheaper set, but I think I might be buying this one today now!
Yes it works great, but as mentioned by @fenrus, use a light DOC. I use .02 for end grain cutting boards, as documented here: So many scraps what to do
Guys thanks for the input. I just wanted to make sure what I was thinking is correct. The bit we will be using is a actually a round nose bit for fluting. For some reason bowl bit was stuck in my head. But a bowl bit will come in handy for something else down the line.
Pics will be posted when completed.
