Anyone have any Canadian sources for drill bits? Currently I’m looking for 4mm (5/32) dia. drill bits for either peck drilling or continuous bore up to 1". I will need a few other sizes. Found a few in the states but they don’t ship to Canada. Also found this bit but I doubt it would be balanced in the collet because of the notch. Thoughts? CNC Drill Bits - RH Twist Drill Bit 4mm - CNC-Tool.com
The main source I use is https://ca.robotshop.com/. https://www.busybeetools.com has some, Amazon has cheaper ones, https://kjpselecthardwoods.com if you’re in the far eastern lands. Lee Valley as well, but once you go for the expensive stuff, it’s usually cheaper on Amazon.
I have used https://www.kbctools.ca/ Do not carry absolutely every possibility but carry most everything.
Thanks for the resources. I will definitely check them out and yes kjpselecthardwoods is close by ![]()
@Ataraxia Your link is to a drill bit. I assume that you are looking for CNC end mills, though. Yes? Most drill bits are not happy with the speeds that our routers/spindles turn. That’s why I’m asking.
