I was asked to cut out a part for a friends Pick-N-Place machine. Carbide Create is able to generate a tool path for the holes, but the outside vector is failing for some reason. I just keep getting an empty toolpath. Here is the SVG file I was provided:
I have tried to “fix” the SVG in several different programs and keep getting the same result. I also updated to the latest available CC (778) and still no dice.
which I brought into CC 767. CC Complained that it had 84 open vectors which I used the “Try to Join” option in CC to correct. That created the file I originally uploaded.
