Picked up a new Surface tablet today and got it all loaded up. When I try to hook up to my ProXL, it will connect but then hangs halfway through initialization. Checks the zeros, but then just stops.
Tried a few times powering off and re-initializing to no avail.
Hooked PC back up and zero issue.
Anybody else dealt with this or can guide troubleshooting?
On the new machine connect and then go to settings and send the configuration. Uncheck the BitSetter in the second tab and later you can configure the BitSetter. Go to the first tab and pick your machine and Z and send configuration.
Mostly the configuration is configuring Carbide Motion. If you have already sent the config try again and be sure to send the correct machine and Z (leadscrew z-plus, ballscrew HDZ).
Thank you. Right after I posted, I found same issue on another thread and started down this path. Unfortunately, now I have a bigger issue. Will separate post.
