Cannot Open This File Anymore
I have had this file opened before and cut it just fine. Now I cannot open the file.
Can someone see if they can open it and rename it and post it?
Outlet Expander.c2d (56 KB)
Not sure if I used V8 or V7. But my V7 is not working anymore for some reason. I need to re-install it.
I downloaded the file and the file opened but was blank in both v7 and v8. Seems like there is nothing in the file. So is that what is wrong or will it not physically open on your computer. Hopefully you have a back for your computer so you could try to restore the file.
Weird.Thanks for trying. It was a very simple project except that it took a few iterations to get the size correct. Nothing I cannot redo.
Thanks again.
Check and see if you can restore a backup version made at a time when the file was working.
