First, is the machine mechanically sound? All tighteners fastened? If you put a probing pin in the spindle and push/pull on it, does anything move?
If the machine is mechanically sound what material are you cutting? Using what tooling at what feeds and speeds? To what depth? If cutting deeper than half the endmill diameter, recommend adding offset geometry and cutting as a pocket down to tab height or the penultimate pass:
