Hi everyone,
is it normal that i can’t edit the tool that i added in the user end mill section? I see that some users in the forum have the same problem years ago but does this problem still persist? Since i’m using a french keyboard, i can only enter commas (when i try to enter dot, it simply doesn’t work) and after i finish entering the settings, when i click “ok”, the “angle included” is highlighted without any possibility of editing it (because it is greyed out). Are there solutions or it is like that in Carbide Create? Thank in advance.
I finally add my tool. For those encountering this problem, you can add your tool in “New tool>Engraver mill” instead of “New tool>End mills”.
This should work in the now stable 815 build:
If it doesn’t, post a screen grab showing what your editing window shows and we will look into this with you.
Thanks William, i’m downloading it now to test it.
Update : It is working now. This version is better than the 813 that i had installed. Now i can even enter dots. Before, i had to change all the dots to commas before i could click on “ok” to validate my settings. Thanks, that’s awesome.
