Ok used the XXL on Friday ran a bunch of jobs no problem at all. Today fired up the machine secure my stock go to home machine and when it arrives at the back right it for the homing sequence it crashes into the faceplate quite a few times and then stops. I took off the control cover and checked to see if the homing switches would light up on the board when depressed manually. All of the homing switches work . Any ideas?? Running CM4.0.410
Are the homing switches being hit when you home?
check $22=1
Now its fine!! Very weird did it 3 times in a row, Shut down the computer, reboot, and now its fine!
