anyone able to get a zero on the edge (lower left) of the pro bed? seems like my x travel is limited. The x travels further to the right than it can to the left. Is this a software issue?
I could be wrong, but I’m pretty sure when you hit the max distance on the x, in the left direction, you’re at zero on the x axis. It should be at the centreline of the spindal.
This is actually how I zero my x and y when I’m cutting on an 8" x 8" piece of wood - I do a rapid move to the bottom left and zero the x and y. Love this method because it’s repeatable.
I believe on your machine the spindal carriage moves farther to the right because that’s where it touches off against the tool probe.
my lower left spindle line isn’t aligned to the 8x8 bed’s corner. The Y is ok. The x centerline is about 2mm from the bed’s edge
