I bent the silver open wrench for collet. Found my other open wrenches are too thick to fit in. I measured the size will be 13mm opening, with 5mm max thickness. Want to confirm this size before I order online. Thanks.
I am using this router that comes with the cnc. Carbide Compact Router - Carbide 3D
WillAdams
(William Adams (Carbide 3D))
May 15, 2022, 8:54pm
2
Yes, 13mm — needs to be low profile, and 22mm (stubby is best).
Carbide Compact Router/Makita RT0700/0700 shaft and collet/nut wrench sizes:
13mm — note that this must be low profile.
https://www.amazon.com/gp/product/B0791ZS89G
Bicycle cone wrenches work as well such as the 13mm Park Tool PT-09 Shop Cone Wrench
Asahi low profile 11/13mm wrench
McMaster-Carr Tight-Clearance Open-End Wrench with Black Finish, 13 mm Size, 4" Overall Length (sourced from Martin as of mid-2020)
22mm — a stubby wrench is well-suited for this, and handier due to the low torque requirements
Some folks get sets:
system
(system)
Closed
June 14, 2022, 8:49pm
3
