I want to add by hand dogbones to a design.
I just add a circle in an edge and use the boolean subtract. Fore some cases ist works, but it seems to have problems if the path is not in 90°:
In the picture you can see a good example and a bad example, both done in the same way.
Attached the file with the project: FruitPlate_all_01_Bones.c2d (2.1 MB)
I do not know if this is a bug or if I do something wrong
