Unfortunately your file crashes my machine (Windows 10, build 1703, so not a valid test since I’m not up-to-date) — hopefully someone who is willing to stay up-to-date with an OS will be able to look at your file presently.
Yes, it was a strange error as I would have thought the C++ Redistributable would have included it.
Anyway, after uninstalling, restarting my test system, accidentally installing CCv415, then installing CCv433 over v415, it now loads. Previously I had installed v433 in a different folder than ‘CarbideCreate’. So I’m not sure as to the why.
My test system also runs Windows 10 Fast Preview builds - which currently sits at v19030.1
same error here. I’ve always uninstalled prior and installed new.version. If you do that you are missing the TBB file. I installed 431, then the new unstable 433 version and it works.
I also install der the “unstable” on windows 7, but why is only “MDF” in the materials possible?
Is it for feed and speed important? Or is it to set over the router and the tools?
Why is only “MDF” possible? A problem with the unstable version?
Will: does that make any difference except for previewing the project? I was checking the previous versions and there were no changes to the recommended F&S for the project based on the material selected. Are there any other use for the material selection?
