I’ve just got the Shapeoko XXL, and just started with CNC. I know CAD og 3D-printing from before.
The Carbide Create 474 has a very noticable bug, which I cannot fathom no one else is pointing out.
Is the issue my norwegian windows? I have tried two computers, and two laptops, same issue on every one.
The bug:
Every single place I enter a number, the number will not change, if I try changing after the decimal point. Example: Change from 0.000 to 0.1
Starting poin:
I’m afraid our software isn’t properly internationalized and it requires that the decimal separator be set to a period (.) — it won’t work when the decimal separator is set to a comma (,) — you’ll need to make this change in your OS settings.
This is an OS-level setting.
Mac OS X:
System Preferences | Languages & Region | Advanced | Number Separators | Decimal — change that to a period.
Windows:
Changing the decimal separator in Windows should be:
Start | Windows System | Control Panel | Change Date Time or Number Settings (left pane) | Additional Settings (button in lower right of dialog box) | Decimal symbol — change that to a period.
If that doesn’t help, let us know and we’ll help you puzzle it out.
Fantastic! I did the change, but same fault.
Did a reboot, and it works perfect!
I really could not understand this bug, could not get anything done!
Thanks again.
