Carbide Create 756 0 RPM
How can I engrave a pocket at O RPM. I am using Carbide Create 756. Before version I erase speed in g-code, now I cant do it. I can use 0 RPM in regular contour but not on pocket.
Turn off the router?
I was able to replicate this and have put in a bug report.
Nomad 883, cant turn of spindle.
Until this is fixed, you can extract the G-code from the .c2d file by:
  • connecting to the machine and using the preview pane to write out the G-code
  • using the website linked at: Carbide Create V7
Thanks Will, when I load a Job in CM I select save g code to file, and now I have independent g-code I can modify. Thank You.
