Carbide create 757
Hello! With version 757 of Carbide Create, I can no add Tabs. I no have access to the Edit Tabs. I can only change the dimensions. But I can’t add them as before by clicking on the outline of the cut shape. Is this a bug in this version?
As noted in the announcement:
https://carbide3d.com/blog/carbide-create-v7/
Tabs are now a part of the vectors, not contour toolpaths
We added a new tab command to add tabs to a vector. If you copy the vector, you copy the tabs too. This should be helpful for users that are doing production work where they may want to fine-tune the machining of a single item and then copy and paste an array of them for full production.
Look for the new command here:
New tabs command
Thank you for your help. I’m so happy this morning to see that it’s working. Thank you so much!
