I’m having an issue importing DXF files generated by OnShape. The units in the DXF (MM) always seem to be interpreted as inches regardless of how I have the job’s units configured in the software.
I have no issue modifying the DXF header information to force the unit conversion to be accurate, I’m just not sure what I need to edit.
Reading through some articles online, the tag is supposed to be INSUNITS but changing that manually between 1 and 4 for INCHES or MM doesn’t seem to impact the import.
Any advice?
James Webb Mirror Assembly - Part 19.dxf (108.3 KB)
