Right now, the ‘default’ GCODE filename is a global, persistent property. So, when you start a new project, and go to save the GCODE, you get a filename that is almost certainly wrong, and may overwrite something you intended to keep.
The most recent GCODE filename should be remembered as part of the .c2d file, and the default GCODE name should be the same as the Create filename, but with the ‘nc’ extension.
