I’m having a problem using CC. I’m trying to cut slots for some wooden holding clamps…very simple. I select the rectangle tool and set my size and location of it on the work piece. I repeat the procedure for the second slot. I select the first rectangle, select contour and select pocket. Once I click ok it shows the blue line and blackened out area in the rectangle. Here is were the problem comes into play. The right rectangle will not let me apply a pocket to it. It will let me apply an outside cut but not a pocket. It’s only on the right rectangle. Is this a software glitch or something I’m doing wrong? Also, this happens on both computers I’m using.
Thank you William. I deleted the file. The next day I started over as a new project. I never was able to finish because I received an error message that the program was not responding and had to be shut down. The program has done that a few times in my short time of using it. I have since purchased other cad/cam software and moved on. It’s a shame because CC would have done everything I need at this point in my CNC’ing but it’s just too buggy.
