Carbide Create - How do I basically add a custom tab to hold a floating section secure?
I have a logo to cut out with a hand in it. There are a couple of fingertips that have a fingernail “line” that would remain but is not attached to the main section of the logo.
I have tried tinkering with the Boolean weld/intersection/etc options and I can’t quite figure out how to do it.
I just need a tab that is maybe half the material thickness in height, to remain and keep the fingernail line in place.
You will need to duplicate both pieces of geometry:
Then draw in something to connect them:
Union this with the inner geometry, then punch the new geometry out of the outer geometry, or use Trim Vectors:
Delete everything which is not needed:
until one arrives at:
OK
OK
Then assign two separate toolpaths:
which previews as:
Attached.
cc7_tab_example.c2d (64 KB)
THANK YOU SO MUCH. I appreciate the time and effort spent to provide the similar example!
