Do I need to purchase CC pro to create g code or can I do it with free version.
If you need to export gcode to use with another machine you need the the pro version of version 7. Version 6 is still available and the free version of version 6 will export gcode.
If you are using a Carbide 3D machine and running it with Carbide Motion you do not need the gCode. The newer versions of Carbide Motion will run the C2D file directly.
Also, if you have a Carbide machine, then Carbide Motion will allow you to export the G Code once you connect to the machine.
I think the website still works too. You can extract G-code from a .c2d file here: Extract GCode from Carbide Create V7
So, no you don’t need pro to create g-code
