Hi there, I’m using a 0.3mm diameter permament maker pen with a home made GRBL CNC.
I have a drawing it consist of 0.4mm lines and some little rectangles sized 1x2mm for example. I want draw this all fine details as much as there is no outline offset error.
To do this I created one 0.4mm, 90 degree tool mimicking my pen. It will be good but there is only one problem I need to solve, with this 0.4mm tool, the pen draws all lines 2 times. I want to make it one. Step over is 0.3mm, max depth 0.001mm, starting depth is 0.0, tools depth per pass 0.001.
What can I do for make the pen pass over all lines only once?
