Carbide Create Pro ... Drilling
Hi All,
I just added a drilling operation in my project. .125" thick material.
I set all the parameters as needed and used a BitSetter for corners and top of material, double checked it too. All good.
The drill operation is eight .062" dia. holes, I selected the PECK DRILL function and left all the settings as is with the TOP as the start and depth set as .140" from the top surface.
The issue: The drill starts about .25 height and never touches the material. I had this happen before.
Is it a bug or am I missing something in the setup?
File attached.
Stab Base 1-8 Thk-A.c2d (68 KB)
Thanks for any help on this ~ KAP
Preview of the G-code:
matches the 3D preview in Carbide Create:
could the #102 have gotten pushed up into the collet?
I’d re-zero the Z-axis and re-run the drilling toolpaths only.
I will reset the ZERO and try again. The .062" bit has a 1/4" shank and I did snug it so I do not think it moved.
Thanks ~ KAP
For some reason the BitSetter never Zero’d out. The 2nd time was a charm.
Thanks ~KAP
If you used the BitZero to set your X Y and Z zero the .125" is too thin if doing all 3. You would do the X and Y and then do the Z separately on top of the material. If the BitZero was on the spoilboard and on the corner you were not touching the bottom of the Bitzero. That would make your Z zero too high.
