There’s a lot of duplication of endmill data in the tool library. Right now the physical details of each mill has to be entered in each library.
There’s also no filtering. If my machine is a Shapeoko, and my stock is MDF, why are all these other libraries shown to me by default?
Even if physically more than one file, the tool library should appear as one unified DB. As such, each tool’s physical details should only appear once, and then a set of ‘feeds and speeds’ for that tool should also be qualified by machine and stock type.
Right,but the data for a particular endmill should appear once, and then multiple rows in the DB should reference it. Each row in the DB has Machine, Material, and feeds and speeds, and a reference to the endmill data.
