Placeholder for moved post.
Hi Guys,
Is it possible to add things like Tool & Cut Depth against each tool path to save you having to right click on tool path and edit to be able to see what you have done??
This would be really handy and also prevent you from accidentally deleting tool path, which I have done multiple times!
Also the ability to enable/disable/delete multiple lines by ticking a check box against each tool path??
Regards
Chris
@WillAdams not sure if I’ve posted this idea in the right place, but wondered if you can pass on?
Regards
Chris
We’ve had a couple of suggestions along these lines — we’ll do our best to review them all and work out what seems to be best to implement.
Thanks Will, do you have a forum specifically for these sorts of ideas?
As I have a few
Regards
Chris
We actually have a forum for this:
which this will be moved to.
