The Toolpath preview in Carbide Create is not the path my router takes in Carbide Motion. Does Carbide Motion just do it’s own thing. Not sure it matters, just curious. Also, in Carbide Create, I told it to drill holes in 1 pass. When Carbide Motion takes over, it drill holes in 3 passes. Am I missing something obvious.
The motion in Carbide Motion should match that you have set up in Carbide Create when sent on a machine which is mechanically sound — for any files which don’t match up, send both the .c2d file and generated G-Code in to support@carbide3d.com
