With all the talk of speeding workflow up with better workflow, are we not spending time with an extra popup when selecting a toolpath in CC ? and confusing vector selection ?
When you select a toolpath. It pops up a box and ask “Cancel - Use current selection - Select by layer”.
Next the toolpath comes up and it again has an option to pick vectors ???
These get me confused. ![]()
If you pick “change vectors”, it brings up the first pop up again “Cancel - Use current selection - Select by layer” Hmm OK but one click and then a popup to get 2 clicks
Just add the one extra button to the toolpath form and skip the popup.
And if you click on another vector on the drawing and then hit [“Select” current vectors], it appears to puts it back???. WTH, is not what I just clicked on the drawing now the current vectors. I believe what it means is [“show” the current selected “toolpaths”] or [“show” the currently matched vectors], not selecting the current vectors. It is not selecting anything, it is showing ! To me vectors are on the drawing, toolpaths are toolpaths that are matched to vectors on the drawing. It is just confusing to me. Better wording could be used.
OK yes I figured it out eventually after playing with it but isn’t it better that it makes sense to new users which in turn reduces support questions ?
This just seems overly confusing and since 99.9% of the time it is, [use current selected vectors], then is this not a a waste of time to have the popup if you can change it in the toolpath for that 0.1% ?
So here is my suggestion:
Why not when opening the toolpath, select the currently selected vectors as a “quick selection” if one or more are selected. Drop the popup, Then under vectors in the toolpath. just have 3 buttons:
Vectors
xxxxxx vectors are selected
[Change to currently selected vectors]
[Select by layer]
[Show current selection]
And as a bonus, the quick action that I mentioned. If a vector is currently selected when you open the toolpath then just use that as preselected vectors, which is the most common choice, if you want to change it then add or change it in the Vector section of the toolpath.
If you want to pick a layer, you don’t have to click on any vector when opening a toolpath. Just select by layer once you are in the toolpath. or add a vector if one was no preselected.
And just to clean the workflow up a bit more, would the vector selection not be at the top as we first pick vectors to create a toolpath out of and then we assign tools to that toolpath. then we define start and depth of that tool … etc
It just seems to save a bunch of time and makes more workflow sense. IMHO
No extra popup, no extra time, no extra clicks, no extra cancel button, cleaner workflow. Less support questions.
Hope I was clear
or did not misunderstand something ![]()
